frsky taranis plus help
iawnski
i have on my frsky taranis plus accst version 2.1.8, how do i put access and accst on it or if u can any help would appreciate
Hi
If it is really a Taranis X9D plus (not a 2019 version) then there is now way to get the Access protocol working on the radio.
This would require a ISRM Hf-Module and that does not exist as an upgrade hardware for Radios older than the 2019 versions.
There is also no external modul for older radios with Access.
Regards Alois
I had a look on the frsky homepage. Are you sure that there is a Accst 2.1.8 (XjT Firmware). I've only found 2.1.0 as the newest version.
Maybe you flashed the ISRM firmware onto the HF module.
Or did you mean the OpenTX version 2.1.8 ?
It is now possible to get the Access protocol to function on the radio if it is indeed a Taranis X9D plus (not a 2019 version).
Hello
Can you please describe how this is done.
I would be very interested in the solution cause I have some youngsters to train with older radios.
regards Alois
