FrSky SP-FLVS - Smart Port Lipo Voltage Sensor
myfivezees
Does anyone know if this sensor will work with a Lithium Ion battery that does not have a balance lead. It would have to be connected via a JR style connector. I am using a Fromeco 5200 mAh ReLion battery.
Thanks for the reply Wayne. Can I use the FBVS-01 with a RX8R receiver ? Presently my X10S shows me the voltage at the receiver which is 5 volts regulated by a Smart Fly Competition 12 but I would like to be able to see the actual voltage of my batteries before being regulated by the Smart Fly.
I am using 2-Fromeco 5200 MAH Lithium Ion Batteries connected to the Smart Fly Competition 12.
You may need to tweek the voltage in the Telemetry page if using this little board. What voltage is the battery pack.
Don't think that receiver or the X8R has the AIN2 port needed for this sensor. Sorry. Most of the other receivers do offer this 1 wire port. In the manual it will say something like:
Voltage Measurement Range via AIN2 (External device): 0-3.3V
So which voltage sensor it the correct one to use with the RX8R receiver ?
Thanks.
Well, you do not have balance ports, so you are kind of out of luck. We used to have a Smart Port basic voltage sensor, but we have not had those for a long time. Anyone else have any ideas?
The voltage of the Lithium Ion battery is higher, but this looks basically like a 1s setup. If so, a sensor with that capability should work.
The MLVSS has a 1s input, even though the specs say 2s-6s (as does the FLVS). You'll probably still need a simple FBVS voltage divider to get the voltage down to something the sensor can handle, but from that point you should be able to adjust the calibration ratio in the Rx to where you want it.
The FLVS sensor is simply a voltage divider. This converts the flight pack voltage down to 0 to 3.3 volts which the receiver can deal with. So either purchase a FLVS or make your own voltage divider using 2 quarter watt resistors. See the attached diagram. This circuit will allow up to 10S battery pack. The RX8R and X8R receiver do not have an A2 input port so these receivers are not suitable. The RX6R, GRX8, the Archer GR6/8 require the voltage divider, the Archer R8-pro can be used without a voltage divider. The Ain2 port is an analog input port. Once you have this working you will need to adjust the A2 voltage in the A2 telemery page using the ratio perimeter so the displayed voltage equals the measured pack voltage. Precision is .1 volts.
@HENNY, why not hook up the MLVSS to the RX8R via the SmartPort connection? That was my point, to get around the need for an A2 input port. Or am I missing something?
Sorry the FBVS.
Yes you could use the MLVSS but you would need to plug it into the balance connector and he said he did not have or want to do that.
Sorry the FBVS.
I know that he only has a power plug, but I would make a parallel connection from the power plug to the MLVSS. Unless that would create ground loop issues. But since this would require an FBVS (or your divider circuit) anyway, there would already be some separation.
