FrSky SBUS & CPPM Decoder
Marty McFly
I used to have "FrSky SBUS Servo Channel Changer", but I can't find it anymore, nor anyone sells it. I have couple of SBUS hubs programed with FrSky SBUS Servo Channel Changer, but since it is no longer available how can I change and assign channel on this SBUS Decoder/Hub? Can I do it from my Ethous Tx?
Guys, not sure if this is the same question raised by Marty or not. I have a channel changer, but it doesn't appear to work. I need to program the 4 channels on a few decoders. Is there a way to don't that using my Tandem XE transmitter/Ethos? The current receiver I'd like to use with SBUS is a RX8R (ACCST).
Thanks,
Larry Fitch
Status for this is as In the link I posted above, you will need Ethos 1.7 and the script (yet to be published) to change the channel setting from an Ethos Tx.
Are you able to use any of the other methods described in the linked post? Do you have any, older, transmitters available?
Mike
Do you have UNI firmware on your receiver? If so, a workaround for using a single SBUS decoder is to enable channel mapping on the SBUS output (but not the PWM outputs), then set up the mapping to get the correct channels on the decoder. As long as the decoder is already decoding the 4 channels as different channels, you should be able to map the SBUS channels as required.
Mike
