Tim Callahan
- Joined
- Mar 2, 2018
- Messages
- 26
- Reaction score
- 1
the instructions for this package are usless for non-tec guys like me. I have no idea how the R9MM receiver is connected to the main receiver in the plane, this goes in a Kappa 35. i need a wiring diagram showing me the connections to and from the two receivers. the mini receiver has 4 ports labeled ch 1 tru 4. it also has a 5 pin plug with s bus out, s port/f port, Gnd, v-in, and inverted s port. where do all thoes ports go? the package has a 4 pin plug with a plastic female connector that could hook to the 4 ports ch 1 -4. there is a 5pin plug that could be used for the other 5 ports. but where do they all go ?? video's showing redundant systems using other receivers show using a standard 3 wire connecton from one receiver to the other that wont work here. the receiver i'm trying to connect it to (the main receiver) is a GRX8.
Can any body help ??
