Frsky GPS sensor set up?
mikeboztx
I posted this in ETHOS area but might be a sensor ?. Not sure if this is a radio ? or a sensor ? X20 radio with a couple of Frsky GPS sensors. Set up with logic switch and special function. It works but calls out 300+ feet in my shop. Is there a way to adjust this? I have several high precision vario sensors that call out somewhere around 2 or 3 feet in the shop.
Mike
Is it possible to have a update for the GPS? It does not sample very quickly and I am not sure if it has ever been updated.
The sampling is a product of the priority FrSky gives to the GPS sensors in the telemetry stream. Newer radios (with ACCESS) do sample from the GPS a lot more often than the older radios (ACCST). It is more an issue of bandwidth. GPS data as I recall is deemed of lowest importance and thus has the lower rate.
This is my understanding of things, but I may be 100% wrong. What I recall from others discussing this subject in the past.
