FrSky Archer Plus R6 Mini-E with ESC HELP
sandman92k
I need some help with the
FrSky Archer Plus R6 Mini-E - 6 Channel Micro w/ 5A Brushed ESC..​
The provided manual is not very ME friendly, i would like to know where the Battery leads connect too, i assume on the back is it AG or GB, is the GB battery with the G ground. and is the AG for the motor?
also what do i use to connect this thing to the computer to program it, Is it through the S port and is there a special cable or is it wifi/bluetooth?
thank you in advance for any help
There are 2 tabs on the back of the receiver. One with a "+" and the other with a "-". Those are the battery pads. Why they do not show this in the manual is beyond me! They are on the same side as the ESC pads. Should be easy to spot on the board itself.
For programming the manual has you covered should you want to modify the basic settings:
Manual for reference:
Hope this helps. It is actually a really nice little receiver.
For the FrSky Archer Plus R6 Mini-E, connect the battery leads to the “GB” port for ground and “AG” for the motor. To program it, you'll need a cable for the S.Port connection—no Wi-Fi or Bluetooth.
To hijack this thread. I cannot get the esc lua script to recognize the receiver. I'm using a Taranis 2019 on OpenTX 2.3.11 ACCST D16. Gyro setup script works properly, no problem. ESC setup script does nothing. Help?
Hi
I do not have a "Archer Plus SR6 Mini-E" but I recon the problem could be caused by the same reason as the Lua scripts not working for the "Archer plus SR8".
If the receiver was bought lately it should have the newest firmware on it (v3.0.1 dated 2024-12-20).
It is possible that the scripts for OpenTX (V1.00 dated 2023-12-15 - one year older) are not working with this firmware.
You could try to downgrade the receiver firmware to version v1.0.10. (If you don't mind the risk)
regards Alois
PS: I also would recommend to carefully check whether the Stab Luas are really working correct. With the SR8 receiver (same Stab scripts) the problem was that the script seemed to work well.
But when I run the script a second time I found that some of the settings had not been stored. There is no error message or similar.
