FrSky has authorized us to share some details on the new X-lite and the new TWIN 2.4 RF system.
First up a quick picture of the S version in the Silver Grey:
I'm a fan of the Xlite radios and use the current X-lite S but have been waiting for this new version with all the trims and Ethos!! Anything else is a gift, and it looks like they packed in a number of gifts!
Non S version in Charcoal Grey looks like this with Ethos running and the screen in the down position:
OK, this is what FrSky says about the S version:
DUAL 2.4G RADIO SYSTEM
The TWIN XLite S is a powerful radio system that features dual 2.4G frequencies simultaneously on the same receiver in TW mode. The TW active-active protocol is different from the general active-standby redundancy solutions, with this protocol, dual 2.4G frequency bands are active on the TWIN series RF module and receiver at the same time. It has two 2.4G internal RF antennas mounted to provide multi- directional and wider coverage for transmitting signals compared to a single antenna design. Taking advantage of these features, the TWIN system can provide less latency and higher reliability at a faster data rate with confidence. It offers resilient RF power options up to 500mW, so this system can ensure long- range control further around tens of kilometers.
In addition to the TW mode, TWIN XLite S also supports ACCST D16, ACCESS, and ELRS 2.4G (Compatible) modes, this means users can benefit from a wide range of compatible receiver options to choose from and bind to when building the RC model.
SLIDE SCREEN & UPGRADED ERGONOMIC COMPACT DESIGN
For a compact and lightweight portable design to carry with, TWIN XLite S radio adopts a 3.5-inch color touch slide-screen, which saves space and ensures the comfort of using other functional trims, buttons, etc. By sliding out the screen, the foldable tab hidden under the screen can be used to attach the strap or other potentially more flexible uses. In addition, TWIN XLite S provides a high-bright matte touch screen, which greatly enhances the visibility of users in strong outdoor sunlight.
The power button and 4 standard trims (for adjusting gimbal sticks) are positioned under the screen. The extra 2 trims and 4 customizable buttons are placed on the radio panel for the convenience of real-time and frequent operation. For example, flying an RC glider, use the extra trims to adjust the angle of the flaps/surface to adapt to the real-time air environment. The momentary buttons, sliders, and switches on the top are easier to reach, and the momentary buttons allow withstanding larger pressure force thanks to the redesigned button cap areas, which bring more comfortable feedback to the fingers.
GYROSCOPE SENSOR
With the integrated 6-axis sensor unit, users can use the TWIN XLite S as a motion-sensing controller to control the inputs of a model during flight or use it to point a camera in the desired direction.
BUILT-IN MASS STORAGE & BATTERY CAPACITY
In order to save the user the trouble of deciding the storage capacity, TWIN XLite S comes with a built-in 4G flash storage that offers plenty of file storage to meet all of your radio's storage needs. And TWIN XLite S included a 4000mAh Li-Po battery, its battery bay is easy to access for replacing the battery and also offers a Type-C port for recharging the battery.
SPECIFICATIONS
• Dimension: 197*131*68mm(L*W*H)
• Weight: 392g(Battery Excl.)/ 459g(Battery Incl.)
• Operating System: ETHOS
• Internal RF Module: TW-ISRM
• Number of Channels: 24 channels
• Operating Temperature: -10°C~60°C (14°F~140°F)
• Battery Bay Size: 68*44.5*13mm(L*W*H)
• Data Transmission & Charging Interface: USB Type-C
• USB Adaptor Voltage and Current: 5V+0.2V, >2.0A
• Built-in Flash Storage: 4G
• LCD Touch-Screen Display Resolution: 480×320
• Compatibility: ACCST D16 / ACCESS / ELRS(Compatible) / TW modes
FEATURES
• Ergonomic and Compact Lightweight design
• Slide Screen Design
• 3.5'' High Bright Matte Touch Screen
• 6 Trims & 4 Quick-Mode Custom Buttons
• 2 Momentary Buttons & 2 Sliders & 4 Switches on the Top
• Fordable Tab for Attaching Radio Strap
• CNC Metal Gimbals with Integrated High-Precision Hall Sensor(S)
• Built-in 6-Axis Gyroscope Sensor
• Upgraded Gimbal Stick Ends
• Built-in Dual 2.4G Band Internal RF Module
• Less Latency with More Range and Higher Reliability at a Faster Data Rate
◦ Supports 4 RF protocols: ACCST D16 / ACCESS / ELRS (Compatible) / TW Mode
▪ TW Mode offers:
• Highly resilient RF module providing dual 2.4G signals working simultaneously
• Long-range control (Tens of kilometers, range varies based on the RF Power settings.)
• Low-latency (<4ms) supporting full telemetry
• External TF card slot for storage extension
• Supports Recharge System for 2S Li-ion Battery
• ETHOS Operating System
TWIN XLite: Charcoal Grey
TWIN XLite S: Silver Gray
GYROSCOPE SENSOR
SPECIFICATIONS
FEATURES
▪ TW Mode offers:
