thenated0g
Moderator
***forgot to post this here, i had posted it over in the "show us what you are working on thread"
So as i stated in the video i made 2 mistakes right at the end which messed up my resin to cloth mix. I forgot to add more resin for the final layer of my layup (peel ply) and the roller sponge needs to soak up some resin before it starts working so i had about 1/3 less resin than i expected and it dried out, plus it only has vacuum for about half the setting time. But i did get to try out the whole process and it went really well. Really happy with the ultracal30 as a mold. Its very easy to use. My mold prep consisted of 2 layers of waxing and it released very easily without any problems.
The outer layer does look ok but it is very spotty, you can see dry spots throughout, but the biggest issue is that its just not very rigid. Even the carbon doesn't feel rigid at all. I know it will add a bunch of rigidity when you have the top and bottom with all those curves glued together. But it did give me confidence that this is going to work. I can very easily see the parting line all the way around. Ill go heavier on the resin this next time and maybe add one more layer of 6oz. This was also my first time using peel ply (which you rip off afterward) and i am very pleased with the rough surface it leaves behind for gluing to later.
At first i was worried about how difficult it would be sliding such a long mold into the bags would be but i had sanding/rounded the edges off of the mold and it slid in very easily for how long it is.
Oh yeah this layup from outside inward:
1.5oz eglass
2x layers of 6oz sglass
After looking at the materials i have on hand i am going to add some more layers of fiberglass and some wood strips in between layers to create spars. Also adding some reinforcing layers in areas where i will be creating holes, elevons, and hatches as well. So it will have about 1.5x more fiberglass overall and about 2 times more in areas where i will be cutting into the shape later.
Then after testing that to see how rigid it is i will do another piece with some colored chiffon cloth, which i have used in the past and looks amazing.
Basically it will be 1.5oz E glass on the mold and than the colored chiffon followed by the rest of the layers of cloth.
top:
bottom:
www.spoonflower.com
1.5oz eglass
top:
Robot coordinates - circuit board - yellow Fabric | Spoonflower
Shop Robot coordinates - circuit board - yellow custom Fabric by coggon_roz_robinson for sale on Spoonflower
www.spoonflower.com
bottom:
jungle charcoal grey Fabric | Spoonflower
jungle charcoal grey custom fabric by elmira_arts for sale on Spoonflower
