Falcon: Spektrum NX Setup File
What is a Spektrum, some new to the block or off brand radio? The Falcon uses a delta elevon mix with motor. What inputs and outputs you want are your preference.
This might best be asked on a Spektrum radio form. But do mention the Delta mix.
Hey Pete - Shouldn't be too hard to program up. Just 2 servos with a delta mix and a throttle. Just make sure you get the throws listed in the Falcon's instruction manual and you will be fine.
Yeah, finally found the manual..
It has some exquisite detail setup-wise.
My only problem is the transmitter. "Delta Mix" is not tb seen anywhere. Actually, I have sort of stumbled into a setup - but when I get proper tip movement for Stick-Back and Stick-Forward, the airleron controls are backwards (i.e. banking to the right with stick makes tips move for banking left and vice-versa). Telling the radio to reverse airleron control just reverses the whole thing to where banking works, but up/down are reversed.
Look for "Elevon" mix. Sorry I do not know what terms Spektrum uses, but your mix weight may need to be a negative number.
Try switching the channel output that you have the servos plugged into. I recall that with many lesser programs it is far more difficult to change the servo response in the program than it is to mechanically change which RX output the servos are plugged into. I think the university of You Tube has some ideas on how to program some of the Spektrum radios. I'm sure there are some on Delta or elevon mixing.
Bingo!
For the benefit of Fellow Spektrum Sufferers:
1) System Setup / Aircraft Type / Wing: Elevon-B & Tail: Normal.
2) Servo Setup / Reverse / RAL=(reversed) & LAL=(reversed)
