I consider it negligent to set throttle on "hold". A few years ago, a current employee of Horizon Hobbies Germany killed a person at an airshow in Hungary and seriously injured several people because he had programmed throttle on "hold". He came out of a downturn with a big Pitts when the system went into failsafe. With the engine throttled or switched off, the 22 kg heavy model would have crashed after about 100 m on the airfield. It flew more than 300 m into the audience at full throttle.
Therefore I am of the opinion that it has to be sure that nothing unforeseen happens with all possible failsafe settings.
From the OTX way receiver failsafe was used once you select receiver failsafe option on the TX and then momentary click the FC button it would capture the current channel positions and use these as the failsafe value. Custom setting lets you manually set any value. However receiver option appears not to be operational on the X20S presently so have to revert to custom at the moment.Was not limiting this to Frsky options. To me "Receiver" is a variation of "Custom". Or perhaps it does something I am not aware of..?
There is a pole at the top of this page.@Wayne How do you want to collect the responses: essay-style (like this), or maybe set up a separate polling form (if the forum software supports that)?
Motor off. I had a motor with prop spin up on the bench when I turned off the transmitter without thinking. Yes I usually take safety precautions.Recently we have been discussing failsafe settings at the shop and I thought it might be interesting to take a quick pole.
Please feel free to discuss your settings and why you have picked them.
Thanks!
Chris, as i would say to our club members in gest like you. Man you need a good whipping and flogging!I am terrible, I admit it. I just dont set any up.
Why not cutoff?A gas/nitro model would want to be to idle but not cutoff.
Failsafe can occur while flying due to temporary loss of signal and 3 seconds later you are back with a connection so bringing the engine to idle maybe a good compromise for such conditions. I guess this is what Rcsoar4fun was suggesting?Why not cutoff?
Why not cutoff?
