I think you'd have to add an extra "switch" in line with the device to cut power. I'm sure there is no PWM to control it.The 1S Lipo idea is a great one. I do have a couple of planes where the receiver is pretty cumbersome to get to. Or could just add a little servo extension into the receivers of all planes. Its usually a little easier to plug into an extension than it is directly into the RX.
For what it's worth, if plugged into an open RX channel, I'd thought about setting it up so that channel can be activated with an on/off tranmitter toggle switch. Would probably just leave it activated all the time while flying, but at least that way you'd have some control over it.
My home hill. People do still fly there regularly.The only slope site I saw is Lichau Soaring - in your neck of the woods. I did not know there is flying going on there still..
I was surprised that the Slot, Coyote and Mission Peak are not on the list (Coyote and Mission are both SBSS flying sites I believe..)Yep, spotted someone flying there a few months back.
I reached out to a club in Watsonville to see if they might be talked into sponsoring Sunset for a FRIA.
For anyone thinking of using this Remote ID module with a 1s lipo, don't forget that you'll need to change one the connectors on either the lipo or the Remote ID module as they are currently both "female" as they are both designed to plug into a receiver. No big deal, just something to remember. I made a short male-male extension so I had maximum flexibility.Are you taking pre-orders?
I'd like to have a couple ready for Spring flying season.
One consideration is the possibility to either power it off of a Rx battery, or possibly use a tiny 350mah 1S battery so the unit is entirely self contained. The reason I'd like the latter is so that I can just move it from model to model at an event if needed with a minimum of hookup. I frankly don't even care if range is less with a 1S, just as long as I can show my plane is "legal" to fly. The only time I expect to actually use the device is if I lose a glider in tall grass or brush.
thank you for developing a RID. Do you have an estimate of when yours will be available, and what its dimensions are. The problem with flight test's is it will be hard to squeeze into planes like the Magnus and some other small fusalages.The new design will have the LED on the board, and also a connector for those that would like an LED remotely.
I was helping the secretary of our club (Seattle Area Soaring Society) who was doing our FRIA's to find out what other soaring clubs were doing and had contacted SBSS about their plans. Last I knew, SBSS was only getting the FRIA for the thermal site at Brigantino Park in Hollister. The FAA makes it challenging to get FRIA's for sites such as public parks or schools which don't have some kind of access control (fences around the flying area), so sadly I suspect it might be impossible to get FRIA's for Coyote Hills and Mission Peak.I was surprised that the Slot, Coyote and Mission Peak are not on the list (Coyote and Mission are both SBSS flying sites I believe..)
