Just finish programing my first model with Ethos. I have to say I'm impressed!
Those that know me are well aware that Bits & Bites and myself don't get along. Or put another way I hate programing!
With that out of the way I decided to play a little mind game. Often I hear that the programing XX is intuitive. Now as an engineer and human (sometimes) I know there is no such thing as intuitive languages (programing or spoken). With Ethos I put this to the test. I tried to program my first model in Ethos without reading the manual!
Now I should give some background about my RC TX programing experiance. In the late 80's & 90's I felt I was rather comfortable with the Ace MicroPro 8000. I used 3 Futaba Super Sevens and never got comfortable with the master slave concept. I always had to go back to Don Edberg's manuals to do even the simplest of programing correction. Then got real comfortable and very happy with the Multiplex Profi 4000 with its object based output focused programing. Had to go backwards to master/slave with the Spektrum DX7 (first gen.) and DX9 with the move to 2.4ghz. Found OpenTX around 2016 and was so happy to again have an output based program structure similar to the great Multiplex Profi 4000.
As with all my learning I try to walk before I run. Here I chose to use a low emotional investment model, a Freewing Venom. This will be a 9ch model. I've been flying these for over a decade. This is a simple model when it come to mixing demands. I generally only need 3 mixes. To correct some knife edge issues, I use Rudder to Aileron and Rudder to Elevator mixes. And for a smooth take off run on concrete I like to decouple the nose gear steering to allow a rather extreme expo curve.
As I knew how to register and bind FrSky's ACCeSS that wasn't a fair test as to the intuitive nature of that part of the TX. Unlike the first gen. OpenTX and the Profi I found that Ethos had a very nice set up wizard. I also found the two flight mixes already set up in the pull down menus. With a little experimentation I got them to work with the dual ailerons just fine. The free mix for the nose gear was again similar to what I was use to with OpenTX or any of the modern TX programs. (Did not need to use a free mix as the rate and weight can be defined as in the initial channel set up menus. )
The only thing that gave me pause was looking for the dual rate and expo. Like OpenTX these function are a bit tedious as each switch position needs to be fully defined with the function you desire. (As Wayne said these can be set up directly in the mixer menus). This does hint to the power and flexibility of Ethos.
Overall programing this simple model without the manual was a lot less frustrating than I thought it would be. It did take about an hour of flailing around, but I did program the model without the manual. I'll now go back through this exercise with the manual to see if there are any hidden features that might make this basic programing more elegant. But for a first time through the program I'm happy to say I have an airplane program that I'm comfortable to fly with.
Next up for Ethos will be to play with curves and logic switches using Mike Shellim's F3F templets.
