EPS Foam Film
Call me silly, but I tend to use thinner material like "cheap" packing tape. I'll apply some to a chunk of glass, and with a sharp hobby knife you can trim to meet the needs of your plane. 1 layer for a light plane, and 2 or 3 for a heavier plane. After it gets nasty, just peel off and install some fresh tape. Works pretty well. For heavier planes the lam film is a better option.
My UMX Conscendo is my desert sloper. My landing zone is asphalt or raw desert, will this film work on EPS foam? https://alofthobbies.com/collections/new-stuff/products/cp-laminating-film-10-mil-x-27
If not what should I use to give it a little protection, most the under fuselage and wing tips.
Thank you
You might consider small skids. I am astonished at how well skids work on a number of my planes that don't have proper landing gear. There are some STLs out there as well.
