E-Tracer build
Do you have any advice on cutting the holes for the tail pushrods?
Is it going to be in the beveled section here?
It looks like the back wall is where the pushrods will line up.
I drilled the holes there and they appear close. I won’t know until the servos are mounted. But the servos bottom out on the other side of the fuse. I need to put spacers under the servo tabs.
I also ordered some MP Jet ball links since someone on here said that they fit better than the ones from TJIRC provided in the kit.
But, the MP Jet are pretty sloppy after they are on. They take a little more force to put on but once they are snapped on, they are actually looser.
They don’t appear better than the factory ones. Maybe I’m wrong but less slop would seem better to me.
I'm not so sure the MP Jet balls should be popped out of their housings. I've never tried that with them. I have always been able to keep the balls in the housings, and they are really nice and tight that way. But on this plane, with the balls being brazed onto the music wire, you don't have much choice.
Yes, play is bad.
Yes, drilling a hole on the back wall is ideal.. As small as practical is best. Don't want to remove gobs of material in the tail boom. Surprised the servos bottomed out, but the Tracer is a rather thin model.
HI Wayne.
The MP Jet housings are flexible, not brittle. Popped out and back in with no issue.
The servos are the FrSky ACT M5213H.
Running 3s, is a 3300 mah pack an appropriate size? its about 260 grams. I expect about 40 amps. 60c packs. I’m not worried about the amp draw, I just dont want to put a battery that is too heavy or too small.
All planes fly better when they are lighter.
I will always suggest the smaller lighter battery, especially for early flights. Get to know the plane before adding weight.
Ok, my power packs are 2200, 3300, 4000, 5000
rx packs I have some between 800-1200 but these probably don't have the C rating I would want.
Go with whatever you can still get CG with. Since this is an electric model, you do not need a receiver battery.
Ok. I’ll start with that one. Thanks.
I reinforced the gap from the firewall to the fuse (where the fuse is molded into the canopy) with epoxy and Kevlar pulp. Do I need to drill a hole in that to provide ventilation for the motor and esc inside the fuse? Or wait and see how it goes first?
I am laser cutting some servo spacer/trays and hopefully get them installed by tomorrow.
Still need to program/solder the ESC.
Any tricks for getting the prop/collet on?
It is always a good idea to have airflow over the motor. Additional holes can be made after the firewall if additional ESC/battery cooling is needed.
There are different ways you can fly this model. And for first flights I will suggest the first method:
Method 1- Power up and fly for some altitude. Cut the motor power, fold the prop and fly around. Get the plane trimmed out and and then do some high speed passes, etc. Turn the power back on as needed to regain altitude. Do this for a little bit, but land early to make sure all temps are good.
Method 2- Power up and fly around and never turn off the power. Again, land early to check the temps.
What issues are you having with the prop collet? Pictures?
Ok.
The tightening screw is hitting the motor shaft and making it hard to get it tight enough. Without putting pressure on it to start compressing the collet I can’t get it to tighten up as the collet just spins.
I think I will have to get it snug, then pull it forward a bit so the screw doesn’t hit the motor shaft and then try to tighten it from there.
Do you scuff any of the surfaces or use any other friction adders?
I have done these on EDF’s and smaller planes before without issue.
I can send a pic later tonight.
The motor is a T-motor AT2826- 900kv.
Do you one of our folding prop spinners? If so, just hold the spinner with one hand and tighten the screw (if turbo style, nut if classic style).
Is you motor shaft super long?
It is the turbo z spinner. The collet spins if i don’t put enough pressure on it.
The shaft is longer than some. I can find another motor if necessary.
Nope, you should be fine. Wondering if you have the wrong sized collet though. What size is the motor shaft? (Best to measure it.)
Motor shaft is 5mm. Measured. The problem with the spinner was I had the cup upside down, so it wasn't pulling against anything. I flipped it over and it tightened right up. Don't mind me. I'm just spinning in circles over here.
I cut the servo spacer/trays and they fit well. I didn't feel like painting them. I guess the servos only come with 3 screws, so you put one on one side in the center and 2 on the other? I'll add the 4th screw on them.
This is what I added to the West Systems epoxy for the firewall fill and fillet.
And, I epoxied the tail on
I'll go check on it in a while before the epoxy has fully hardened in case I need to clean it up. There was definitely a lot more fiddling involved by just having the small holes in the fuse for the ball link horns.
When you cut the flap and ailerons for the control horns, do you just cut the slots on the side where they will be sticking out? Or, do you try and cut a smaller slot and sneak them in from the opening (topside)?
I guess the difference won't really matter.
When using a control horn I only cut the one skin, but I like to have the control horn bottoming out on the other skin, this way the epoxy has something else to grab onto. I use a dremel cut off wheel to cut the skins. Very easy.
