drone build from junk i have
  • Thread starter Thread starter spark23ca
  • Start date Start date
S
spark23ca
Guest
i have a hmx280 with good motors and good esc's i've bought dj naza m lite , a flexybee frame turnigy 9x radio ..for the turnigy i got a frysky gjt jr transmitter telemetry module so the rth would work i think and a FrSky D8R-II PLUS 2.4GHz 8CH Receiver With Telemetery...the flexybee came with a power distribution board .. i've soldered the red and black bigger wires to the board that come from the exc's ...there are 2 more very small wires that come out ...i think they are signal and ground ..they are also red and black..i've looked and looked and looked ..i can not find a wiring diagram or even a hint of how to wire these...all the drone builds that i've seen on forrums and youtube are plug and play ...the plugs for all the drones are 3 wires or at least thats what it looks like ...could someone give me an idea what i'm doing wrong ..or where to start..i've posted on another forrrum and they just said it won't fly ....i still would like to try ...
...i really don't know the lingo ..i'm very new ..ppm all that stuff .. ii'm just very confused..i know about rewiring cars plumbing electrical i've built garages and fixed a thousand cars in them but i'm new to this... i watched alishanmao vid and figured the other side of the naza plug ins out i think ..
Black is rarely used for anything but ground. As there must be a signal, that leaves red for the signal.
Conventionally red is positive voltage. Signal lines are generally white, yellow, or orange.
In your photo of the controller. The red line from the esc will attach to the bottom pin, the black to the top, and there will be no connection to the center pin.
thank you very much ...this is very helpful ..its simple likely for some people but not for me as i'm new at this.. one more question ...does the naza get its power from
pmu modual or is there something i have to plug into the power board from the naza some sites seem to call it the vu modual maybe
PMU = VU. The three pin connector is supposed to plug into X3 of the flight controller. That supplies power to the FC and the power will also feed to the rx when any of the AETR channels are connected to the FC.
