u2builder
Strong User
I recently had an RX6X that "died" after a couple hours. Thinking about possible causes, I wondered if I had created a ground fault when connecting my FBVS-01 analog voltage sensor.
The FBVS-01 has red + and black - wires that connect to the battery on one side and red + and black - wires that originally connected to the D series receivers but can also be connected to the RX4 and 6R using the A2 port for the red wire from the sensor. This is an inexpensive and light weight way to get lipo voltage.
Because the sensor had the black wire, I connected it to the "-" on the RX. I thought it was odd at the time because that "-" could also be used for other Smart Port sensors but it would require splicing wires to also connect the minus from the FBVS-01.
After the RX6X "died" I remembered that back a few years ago there used to be a note attached to the instructions for the FBVS-01 that said connecting the black - wire from the lipo to the sensor and then from the sensor to the RX could cause a ground loop and this could damage the RX or other telemetry sensors.. This is discussed here: https://openrcforums.com/forum/viewtopic.php?t=4293
Clearly, I had created a ground loop. Whether or not this "killed" my RX6R I don't know. However, I took another RX6R and connected only the red wire from the output of the sensor to the A2 on the RX. I didn't connect the black wire to the "-" on the RX. The voltage of the lipo was displayed correctly. Plus, the "- + S" connections are available for other Smart Port sensors. Even though the FBVS-01 still comes with the red and black wires on the output side I would suggest not connecting the black wire to the RX as the no longer included note used to recommend.
