Does anyone use Markdown formatting when crafting posts?
Ps23Rick
The next update that I'll do, down the road a bit, will have changed support for Markdown and it will need to be manually enabled behind the scenes. I was just wondering if anyone is currently using it.. I may opt to enable it when the time comes, but thought I'd ask. It is turned on right now -- fyi.
Markdown is a text-to-HTML conversion tool for web writers. Markdown allows you to write using an easy-to-read, easy-to-write plain text format, then convert it to structurally valid XHTML (or HTML). The goal forMarkdown's formatting syntax is to be as readable as possible.
