This is more a discussion of the limitation of some CAD programs. First I need to be clear that there are huge differences between CAD (Computer Aided Design) and CAD (Computer Aided Drawing) programs. I'm sure that is clear as mud!
As a former machinist and manufacturing engineer I was comfortable with some of the earlier CAD/CAM programs (Computer Aided Design/Computer Aided Machining [Manufacturing]). Today much of what I see in hobby grade CAD (Computer Aided Design) really are just powerful CAD (Computer Aided Drawing) programs. This is fine as most Hobby CNC machines really only work in 2D. And as engineering hobbyists we aren't asked to do a full blown analysis of the Form Fit and Function of the design. (Well, not unless you are trying to sell me some BS.)
When I was last at Aloft I saw this
fin and was asking why the radius for the ribs were inconsistent? As one of the last generation of machinists taught on manual machines I like to see the print call out standard radius as it helps with the selection of the cutter to be used. (This is just my eye, with the XY table of a laser cutter this is not a concern.)
Talking with
@RafaelAvila I learned that he had to use the brute strength method to generate the radius, as the CAD program he was using has some limitations.
Normally when I draw a corner I just let the lines intersect I then come back and ask the program to add a radius I've defined earlier. And as if by magic, the corner has the radius I defined. I was usually doing this in the 3D model. In a 2D rendition or drawing these left over artifacts often are still in the vector defined code. As such the laser cut file will see these and cut them. I believe Ralael had to draw this with spline of bezier curve tool (brute force) to avoid the unseen cut lines.
This is just me, but I like to see parts without the delicate points. (
See this post and attached drawing) I just get a bad feeling whenever these break off during the build.
Please give the guys at Aloft your feedback during the prototype stage. If there is good reason and it isn't too difficult I'm sure the crew would love to add the feature or your input into the design.
FWIW, All my drawing where done in an antiquated CAD (Computer Aided Drawing) called Canvas 8. For this forum all my drawing are free hand. I haven't set any constraints as I would, if making real engineering drawings. It is best to think of these as sketches at best. (I like to call these cartoons)
