hotdogx
User
I have upgraded my Horus X10S to EXPRESS so I can run ACCESS. I've updated my G-RX6 receivers with ACCESS firmware and they are working fine. I have also updated one of my G-RX8 receivers and it is working fine as well. However, I have two G-RX8 receivers that have XM+ receivers connected to them for redundancy.
1. From what I have been able to determine with my web research, the XM+ receiver cannot be updated with ACCESS firmware. So it appears I will have to replace my XM+ receivers with the M+ ACCESS receivers. Is that correct?
2. If I update my G-RX8 receivers with the ACCESS firmware will they then work OK with the M+ receivers? Or will I have to buy new Archer GR8 receivers?
3. On one of my G-RX8 receivers I am using an SBUS Decoder to provide a total of 10 channels. I'm assuming the SBUS Decoder is independent of the G-RX8 firmware and I should just disconnect it before I upgrade the G-RX8 firmware to ACCESS. Or do I need to leave the SBUS Decoder connected when I update the G-RX8 to ACCESS firmware?
