WOW! WOW! Can a ship be too light?
Just got back from another day of flight testing. This report is going to be a bit long, so you might as well get a cup of tea before we go on.
First the Chrysalis Lite F5-RESt is everything I hoped it would be. This came about from a reworked Chrysalis Lite in F3-RES trim with a diagonally braced balsa V tail. Weight as measured is 426 grams. Down thrust is 7.5° maybe 8° as measure with the stab as a datum. CG is at 90mm, nose length is 190mm from the leading edge to the spinner back plate. Spinner is a CN 25mm, blades are reworked Aeronaut 13x10. Power comes from a 3 cell 350 mAh 70c Thunder Power battery. Motor is a Hacker A10-7 4.4:1 gearbox, ESC is a 20 amp Hobby Wing. That is the hardware report.
Now to the flight report. Even after cutting off another 12mm from the nose I still needed 2 grams of lead to the tail to tame the dive test. I'm not 100% happy with the trim as there are some oddities in the flight profile. In the dive test I still get a bit more pull up than I like. But I don't think I want to go any more tail heavy. In very slow flight I can't get the ship into a deep stall. I can get her almost to stop in the air and drop flat. That is the tail doesn't drop faster than the wings forcing the ship into a deep stall. In this flat stall I can get the nose down and fly out of the stall. The only other time I've seen this is with canard set ups. At this CG 90mm the elevators are flat with the top surface.
As to flight characteristic this has meant that in slow flight the yaw induced drag can appear to stop the forward motion of the aircraft, allowing the aircraft to just fall in a flat horizontal attitude. I'm finding that it is best to push forward stick to get some speed prior to inducing a turn at very low speeds. This feels a bit odd, having to push forward then yaw the plane followed by pulling back on the stick to make the turn. In this trim I was able to work the lift coming off a car van.
Down thrust was a pleasant surprise. In slow level flight I could slam open the throttle as the Chrysalis lite lurched forward as if it was shot from a cannon. There was no pitch change for about 20 meters until the speed started to gently pull the ship into the vertical. On the subject of vertical the 13 x 10 is a much better match as I have positive thrust at zero airspeed with a vertical acceleration until 20 meter. Then the Chrysalis climbs at a very good clip until it goes out of sight. At top of climb I do need to add full down at the same time I close the throttle to control the top of climb stall we usually see. I don't know if I can mix this full down and still have a safe ship for the other parts of the flight profile. With the faster climb I'm finding that I can actually climb to altitude using a lot less power. This has meant that I can get 7 or more climbs per battery charge.
The 800 lb gorilla in the room has been flutter. Well, I tried very thing I could with dives loops spins and full throttle speed runs and found no flutter!
The spoiler was another nice surprise. I had to add 48% up to the spoiler elevator comp. I also had to slow down this comp curve to 0.8 seconds. Now with this curve and reduced speed of the compensation I can bring out the spoiler and see no pitch change, only the speed changes. This really helps hitting the mark on landing.
So while I was hoping to loose more that 15 grams with the modification from F3-RES to F5_RESt I'm actually very happy with how the Chrysalis Lite F5-RESt flies. It wasn't just me but the guys I was flying with where keen to see a classic gas bag playing with so many light thermals. Penetration, covering ground was still a typical problem for an RES ship. But if one found oneself risking an off field landing you could just power back up.
This is both a great sport and RES competition ship. So much so that I've started on my second DJ Aerotech Chrysalis lite. Not sure in what trim but as the V-tail and the wings are the same I won't have to make up my mind for a while.
In the mean time I'll get back to my smaller 1.5 Stika, I'm sure I'll love the added control from a set of ailerons.
https://forum.alofthobbies.com/index.php?threads/stika-f5k.1738/
This is the first time I'm using my new X lite-S game console. I have a bit over an hour of actual stick time on this TX. I have to admit I'm not 100% happy with the ergonomics but with the slow flight of the Chrysalis Lite this hasn't been an issue. I was able to manipulate all three flight controls rather well. I only once missed finding the throttle for a go around.
Now I love having all the power on OpenTX in this little TX! I love all the fine tuning with the curves and speed settings.
Oh, I should also say that the Archer RX performed flawlessly!
