On the spinner question I have a light review of the CN 25mm "Z" hub spinner. They CN have 2 sets of blades that fit real well on the "Z" hub and against narrow nosed F3K type fuselages. These are 7x4 and 6x4 and are matched rather well with the Quad motors that they are intended to be attach.
I'm finding that the CN Models 25mm spinner with Z hub is turning out to be very practical in many of my smaller light F5-RES and F5K models. I did find a minor problem with the CN Models 7x4 blade and the spinner. That is the spinner keeps the blades from fully opening up. This caused a massive...
forum.alofthobbies.com
OK, the Chrysalis 2m is an entry level glider with a focus on being easy to build, strong and easy to repair. It was never intended to be a competition class sailplane. I've never seen it sold with a boom and pod fuselage. This would be contrary to the idea of being easy to build, strong and easy to repair.
The Chrysalis-Lite F3-RES is a competition ship. It was DJAerotech's first entry into the class. It was based on the smaller 1.5m boom and pod hand launch glider. As this wasn't a clean sheet design there are some Issue. First to reach the 2 meter span they needed to add a 0.5m center section. To handle the bending loads the airfoil in this section had to be made thicker. Blending this thick center section into the thinner outer panels resulted in some of the carbon spar caps needing to be preloaded while building the outer panels. (Not really a problem just a bit more work on the building board).
And then there was the carbon tail boom. This proved to be the Achilles heal of the design! It allowed (encouraged) flutter! It wasn't until late in the production life that the true cause was found. That is because of the very small diameter of the tapered tail boom. DJArotech used far too small a set of control horns for the V-Tail flippers. This became a geometry issue with the control system. Don Stackhouse knew this but thought that as this was a competition ship that the builders would know how to hinge and set up control linkages to make this not an issue on the weak F3-RES high starts (8lb pull). This proved to be a bad assumption! At the time on introduction Don knew the tail boom was too small and was expecting a new tapered boom to come onto the kite market, it never happened. As the flutter reports came in Don came up with the upgraded diagonally braced balsa V-Tail. (I added the diagonal braces when I first saw the tail of the original bass wood tail). This did not address the linkage issues. So a second upgrade was made known as the "U" tail. ( I choose to go with the diagonally braced balsa tail for weight savings and that I didn't think I will reach the speed we reach on a high start with the motorized F5 RESt).
I like the fully fleshed out fuselages as they are often stronger, lighter and easier to build. The only advantage I see in the carbon tail boom is speed of construction and then it is just the amount of time saved sanding the balsa fuse to shape. Then there are the problems with repair.
The Chrysalis-Lite F3-RES fuselage has too short a nose resulting in the need for far too much nose weight. This killed the performance on the weak high start as one needed to add 30g to 50g to get the balance even to 90mm. While the The Chrysalis-Lite F3-RES build nice and light it trims out rather heavy for its class at 425 to 435 grams with Oracover lite. The Yellow Jacket is much better here in that most are coming in under 400grams. (This 35 grams (9% penalty) really shows up on the high start. In the glide I find the added weight more often than not actually helps when covering ground looking for lift)
Of the 3 F3-RES ships you mention. The Chrysalis-Lite F3-RES is an also ran not only because of production problems obtaining the proper tapered carbon boom but also because of the short nose.
I don't like the Yellow Jacket's use of round pultruded carbon tubes as spars. This is because the tube is a horrible waste of carbon when it come to resisting the bending and torsional loads of a wing. I also don't like the LE covering sag. (Note DJAerotech on the Chrysalis family, does use a rib profile that minimized this getting the LE shape close to that of a sheeted LE. It recovers all but about 15% of the drag lost to typical LE sag)
I really like the engineering that went into the Ascension. The downside is that it is a much more advanced build with its sheeted LE than the Chrysalis with its diagonally braced open LE. While on paper the Ascension looks to have better performance numbers across the whole flight envelope (against the Chrysalis-lite). The fact that it has about 100 square inches less area means that for most pilots the Chrysalis-Lite will actually fly better. (Is more forgiving near and after the stall).
I go into more design detail with the Chrysalis-lite here.
Login
www.hippocketaeronautics.com
More thought on spoilers
I hate spoiler! With that out of the way here is how I like to actuate spoilers. This set up is known as a drag link. It maintains a possitive connection with the spoiler and servo. Does not need or use any springs or magnets. Adjustments are easily controled by the radio's end point and /or...
I see the question is about an electric 2 meter kits. I don't recommend what I've done with my Chrysalis Lite. It is far too expensive for the geared motor. Then there is the real risk with the prop pivots. I think the Chrysalis 2 meter electric is a great entry level electric glider in the same vein as the old Astro Flight Challenger! I don't like the Ascension electric as sold by DJArotech as it looks gross with that large motor and spinner. I'd also like to see more wing on the Ascension as an electric.
