Glenn Beer
Active User
Well said. In parallel - I’ve spent too many hours lost in the rabbit hole that is Linux to ever want to install it again.
Yep, my fall back thought process is if it doesn't make sense; follow the money. But in this case that falls short.I get mad enough trying to figure out a cell phone contract, why would I want to mess with Linux? LOL
(I still don't understand how I was able to get $600 back on my last phone renewal by adding 2 ghost phone lines that will cost me $10 a month and I can cancel them in 1 year.)
Yes and NO.Konrad, Wayne,
Question about the ACCST ACCESS protocols. I have an archer Rx i haven't bound to my X9lite yet. If i up date the firmware to the new ACCESS will i lose the ability to use ACCST too? Currently i can select either protocol in my menu when binding a Rx. So if I update the ACCESS do I have to update all my Rxs? Just trying to figure what is in store for me.
Thanks,
Hank
In the old days of geared Speed 400 LMR we did have some small 25mm to 29mm spinner that had much smaller blade roots. But I don't think any of them had the "Z" hub made popular by the F5B ships. Guys were trying to use these small blades at much higher rpm and power with the inevitable thrown blades. This is why in the age of the brushless motor we have seen the small root blade all but disappear from the market. I think Graupner and Aeronaut have pulled all their small root blades.Yes - the CN 25mm is not intended to work with existing blades. I'm not sure if any of the 25mm spinners are designed to work with the larger blades.
Have I made any complaint about the CN spinner and the fitting of blades for geared applications? I have pointed out concerns that "I" must deal with, when fitting things that never were intended to work together. These issues are my responsibilities. I thought I was clear that this modification is not a consumer level exercise .Anyhow, that is enough of this topic for this thread. I do not think your complaints are valid, you are trying to make products work together that are not intended to work together.
That folded requirement is why that blade root goes up so much cutting into the black spinner cone. This is done to allow the blade to get past the nose and fold back along the fuselage. One way to do this is with the blade root or to widen the hub's pin to pin diameter. But then we would loose the pin retention feature of the black plastic spinner cone.At 25mm you run into packaging challenges. With the new prop building methods you can get away with much smaller hubs on the props now. To be clear, I am not talking about mass produced blades, but hand laid carbon blades. That is what we see being developed for these new spinners. Also the blades are designed to sit very flat when folded.
