Displaying mixed settings
48thFleet
Strong User
On my Tandem XE, I have a main (lower) display set up to display 6 windows. Two of the windows are set up to display analog settings, throttle starboard and throttle port. ( yes it is a ship) The displays work beautifully, however, when I engage my throttle mix(combining both throttles to my Starboard throttle) the display does not show the commanded(slaved) channel as responding to the mix. The mix works fine, I simply do not have an indication that the slave channel is responding. Is there a simple(that's me) way to get the display to reflect the mixed command on both channels?
Thanks
Make sure your source is called out correctly. Not having the radio to play with, I think there may be different ways to call out the monitoring. You want to make sure you are watching the channel "output", not the "input". The output will include any mixing that is altering the input.
I have no idea what they may use to call this out.
In other words, you do not want to monitor the gimbal stick, but the channel that is driving the motor.
Got it Wayne. Thank you. You are correct. I had my windows set to the analog inputs, but when I changed them to the channel setting, it works beautifully!
