B
Bingojamas
Guest
Hello all. A few quick questions...
1. FrSKY instructions say, "The location of the antenna should be such that there is no metal touching the antanna after it is mounted." Does that mean the antenna base has to to isolated from a Tx case if it is metal like a lot of the older Futabas? Please clarify.
2. When would the 4 pin connector on the side of the module ever be used? I don't believe any "dashboard" is currently available, and what is the probability of a Firmware upgrade?
3. The RSSI function works great. As far as a low Rx voltage alarm, at what level? Is is something that can be adjusted if, for example, you are using a 4 cell Rx pack to power only the electronics.
Thanks in advance for any input.
