Hawaii Sloper
Looks like @thenated0g mini solius "Plank" build.Here we have the Genesisi 2 - a beautiful 'almost pure' flying wing...well its got that little tissue of a Horizontal stab perched on top of the fin...but...
I know this has been modelled several times but I'm not sure of the results.
One thing it does illustrate - in the hunt for stability with flying wings there are three main variations:
1. Swept back - probably the most common variation with stability in flight quite easy to achieve.
2. Non - or very slightly swept plank - probably second most common variation - but one of the hardest to get right interms of stability.
3. The swept forward configuration - oddly stability with this planform is not hard to achieve but many people think it looks a bit weird so they tend to shy away.
IF and its a BIG IF you can get the geometry and aerofoils right to achieve the amount of stability needed i.e. not longitudinally over-stable as some lower aspect ratio swept wings (Forwards or backwards) can be, then the plank planform will be the fastest and most efficient. But...its really not that easy to get it all right and working together.
More thought and experimentation is needed.
Doc.View attachment 14656View attachment 14657
Multiplex Mini Solius --> RC Conversion
It is around the middle of the wing. Don't recall the exact position, but it is on the spar in the above pics..
