smirkracing2024
Punishment fits the crime.
Was just talking with Jarron and think we have a build method for the wing.
I like that. I've been thinking of doing something along those lines for LE sanding on my next build. Haven't fleshed it out.Part of the sanding blocks have no sandpaper and are guided by the wood block itself.
Love it!
You might need to move the wing back some as it sounds like a very light battery and motor will be used.
For the Tantrum I'm debating using the carbon on the outside of the fuselage. Make it is visual aspect of the plane.It will have grooves for the carbon. Just an idea. Could save a bit of weight and makes it easier to glue. Not sure I have seen anyone do it this way.
My concern is overall weight gain from printing zapping some of the energy from the plane. So the fuselage may go to wood if this is deemed worthy of being a kit. Last night I was thinking I probably need a higher KV motor. I really need to run some calcs on the setup, but have little time. Today probably zero time to play with it.![]()
Exactly my thought too.I think carbon on the outside sounds just fine. Could look cool to have think black 'racing stripes' perhaps.
