Converting a DSM Tiny 7 Quad to a XM RX
Gerty64p
Bought a tiny7 that came with a DSM RX. After getting decided I wanted to go FrSky Bought a QX 7 and an XM RX removed the DSM RX installed the XM. Got everything set up in Beataflight but it wants to set it to PPM is that the same as Sbus output ?
I can’t see a way to change to Sbus What am I doing wrong I need some help
You will need to find the Sbus setting, and figure out what port on the flight controller to use, it probably will not be the same as the DSM port. PWM is not going to work, that would be a servo wire for each channel, PWM is normal servo outputs.
