Composite skins (Balsa verses Foam) on molded composite models.
As I’m ambivalent (of two minds) on the subject, I’d like to ask what is your take on the subject of wing skin materials?
I like Foam skins such as Rohacell as they are man made they are very consistent in their properties. Being a plastic they closely match the thermal characteristic of the epoxy matrixes. I like that because they are uniform (monolithic) there is no fiber to split from impact. That is damage stays localized. I also like that foam is impervious to water. This is real nice when wet sanding during any repair attempt. The only real down side I see to the use of foam as a composite skin is that it is much more prone to dents (hanger rash).
Balsa it appears to be a bit more durable when looked at for day to day wear (less hanger rash). But I find it is not as stable to changes in heat and humidity. I find it much more difficult to repair. Impact damage tends to run away from the point of impact following the wood grain. Also I can’t sand the fiber epoxy lay ups using the wet sanding method as the balsa swells when exposed to water. Unfortunately it shrinks when it dries causing ripples in the shin surface.
So what do you look for in the skin material of your composite models?
