I just spent the better part of a day grinding out legacy control horns from my modern composite ship.
I’d like to learn why composites ships haven’t fully moved away from the classic control horn we first became familiar with way back in the days of balsa wood models?
I see an opportunity to make a better product. By furnishing a pocket for modern control drives such and RDS of IDS we can have stronger and easier to assemble models.
As it is I had to cut into the bottom laminate of the top skin of the control surface. With heavy carbon layup it is possible to remove the fiber control horn and grind out a pocket for the IDS without too much surface damage. But on lighter glass layup I’m finding that it is all but impossible to make the IDS pocket without some surface finish damage. On my last such model, the Gremlin, the skins show heat damage from the rotary cutter and there are a few break throughs on the outside skin.
I see no need for a modern moldie to still be set up for the classic control horn. Is there reason that composite OEMs don’t offer their control surfaces with pockets to accept IDS or other drive system? Having the control surface set up for the classic control horn appears to me to cost a lot in potential strength and results in a lot of installation stress for the assembler/owner.
Some OEMs leave off the control horn. This is great as it minimizes the chances of the rotary burr damaging the wing while trying to remove the classic control horn. But this still leaves the inside skin needing to be removed to make room for the needed pocket.
I’d like to put forward that the OEMs of composites offer their controls with the pocket supplied at the time of manufacture. A pocket like I show would offer 25% more fibers across the drive area of the control surface, as the inside skin need not be cut. It would still offer those that want to use the classic obsolete horn that option. Without forcing those of use wanting the benefits of a modern drive system suffering the strength loss.
Some may want to read this sister thread.
forum.alofthobbies.com
Servorahmen IDS servo mounts etc - step by step install?
Hi Guys, I'm fitting out an Aresti 2M aerobatics plane right now, and I'm using the Aloft supplied Servorahmen type servo IDS system with 2 x try out "mystery" (read "Chinese") wing servos and 2 x KST wing type. Problem I quickly found is there does not seem to be any full...
