The pilot informed me those are for babies, and he is almost a day old now, so no chutes!How about a parachute for the pilot?
OK, how about wings and a proper CG just in case the magnet is made in China?The pilot informed me those are for babies, and he is almost a day old now, so no chutes!
Look more like PAT then Bob..Bob is on the site:
Carbon Falcon Pilot Kit (Bob)
Need a pilot to fly your Carbon Falcon? We have just the guy for you. Meet Bob! Bob is a seasoned veteran of the hang glider scene, he has seen and and done it all. He has his H-5 rating, so he is good to go with all sorts of acrobatics and skills. His preferred airframe is the Carbon Falcon...alofthobbies.com
They have two holes like this? If so does not matter the side if you have only 1 the holes should be to the leftStarted building my Carbon Falcon this weekend and got to the step of installing the servo mount on page 11. It says to measure 141mm from one end of the keel tube and apply tape then slide the servo mount up to that mark. It looks like the mount was already installed and glued. One length of the tube is 131mm and the other is 146mm from the mount. Can anyone tell me which side is supposed to go toward the front? There are two screw holes on the mount so I cannot tell which side is forward and don't want to mess up the CG.
Yes, two holes like that. On one side of the mount, the carbon fiber rod measures about 131mm. The other side of the mount, the rod measures about 146mm. Neither side measures 141mm as is stated in the manual so I don't know which end of the keel tube point to the front. Logically, I would think the 131mm section would be toward the front half making sure the CG was forward, but my luck I would be wrong and have to buy everything again.They have two holes like this? If so does not matter the side if you have only 1 the holes should be to the left
I hope this picture clarify your needs.Yes, two holes like that. On one side of the mount, the carbon fiber rod measures about 131mm. The other side of the mount, the rod measures about 146mm. Neither side measures 141mm as is stated in the manual so I don't know which end of the keel tube point to the front. Logically, I would think the 131mm section would be toward the front half making sure the CG was forward, but my luck I would be wrong and have to buy everything again.
That is exactly what I was looking for. Thanks for the helpI hope this picture clarify your needs.View attachment 15049View attachment 15050
