Carbon Falcon problem and temporary fix
cricket
First post here, then back to lurking...
My wife and I are planning an extended road trip from Kansas City to the western edge of Idaho to visit my sister. I want to take a plane and used this as an excuse to purchase a quick build Carbon Falcon. My thinking says a section of PVC tubing would be great protection from coolers and luggage.
Assembly went well up to the point of installing the rubber bands. That’s when I found the left leading edge tube didn’t have a notch in its fitting.
I emailed Aloft Hobbies about the problem early in the morning and parts are on the way. In the meantime, I considered temporary fixes and came up with something workable.
This is a section of bamboo skewer drilled through the center with a piece of the carbon fiber rod CA glued in the hole. Cut the skewer short, filed a notch, and coated with thin CA to harden the bamboo. After a few hours drying, my fix looks functional.
I’m still deciding how to mount the receiver and ESC. Once that’s done, it’s time for glide testing.
Here's a suggestion for Aloft. The wall hanger is neat and I may use it if I can find wall space in the basement. Why not give it a second purpose by laser cutting notches at the recommended warperon deflections?
View attachment 19914 View attachment 19915
I'll talk to the guys about it and if it happens I would like to send the first one completely free to you. Can you please contact me inbox and help me picturing it? Cause I'm not sure exactly what you suggested 🤔
And a followup on the original problem. A bag of spare parts arrived this afternoon and the correct item is installed. Huge thanks to Jarron for handling this.
Well then, I should thank you for the effort, too. (y):)
This kind of treatment really speaks well for Aloft Hobbies, too. Well done!
