First time with the X9D+2019 and the RX6R. Succeeded in updating X9D+ to OpenTx 2.3.15. Got the Rx firmware in the SD Firmware folder: RX6R_ACCESS_2.1.7.frsk.
Enabled the External RF port,
connected the Rx with the cross-wire adapter to the External Bay pins.
Rx is flashing Red LED.
Navigate to SD-HC CARD/FIRMWARE/RX6R_ACCESS_2.1.7.frsk,
press scroll wheel,
get menu with "Flash S.Port Device",
press Scroll wheel,
pops up file name, says "Device Resetting", (Red LED stops),
then says "Firmware update error, Device not responding", Red LED resumes blinking.
I have an O'scope, and can see the Tx sending data on the Sbus wire, and I see 7.4 VDC on the power pin.
I see 17.6 usec pulses at 3.3 v, good shape, which implies 57600 baud.
Was expecting 115200 baud or 460800 baud.
How do I know what the OTx baud rate is? and Where do I set it? What should it be?
So many questions.
Thanks
press scroll wheel,
press Scroll wheel,
So many questions.
Thanks
