Buddy Box OpenTX
decreale
I have the Horous X10 Express running Open TX ver 2.3.14-otx and Taranis X9D plus 2019 running OpenTX ver 2.3.15-otx. I set up the X10 as Instructor and the X9D as student using Bluetooth. The X9D does not show Bluetooth Address (Local Address) in the hardware setup. I was able to see three ID when I did Discovery on the instructor transmitter X10Express. I had no idea which ID belonged to the Student, so by process of elimination I tried each one and they all failed. The student transmitter X9D did not act like a student transmitter. The controls on the student transmitter moved regardless of how I had the trainer switch on the Instructor transmitter. I saw on line that the X10 does not see the X9D but if you reverse the process and make the X9D the instructor and the X10 Express the student it works. I have not tried this yet.
Any Ideas, anyone.
Thnak you
Can you detail your setup on both radios for setting up trainer?
I’ve not used the Bluetooth trainer option yet as I only have one OpenTX radio, though I’ve done wired, with my X9D+ 2019 set as master with an old JR radio as the slave. Have you tried a wired trainer setup?
X9D is set to “Slave/Bluetooth” and X10 set to “Master/Bluetooth”?
