The FMS Propeller, 11 x 6, 3-Blade: 1400mm Sky Trainer 182 from our RC airplane Propellers department will help you soar! Find remote control airplane parts, accessories, and supplies at your online hobby store, www.towerhobbies.com!
Be a replacement/upgrade motor for the wife's plane.
YES, reg. CA is the best glue for EPO foam repairs. And the thin stuff is great for tears as its capillary action travels the tear, making a solid repair. Foam Tac is a close second if you need some flexibility or you want the action of a contact cement.
How do you figure? Was it on RCGroops that you were told CA was incompatible with EPO?
Changing to a 2 bladed prop will cut down on tip losses. Up the pitch to 8 or 9 and an 11x8 2 blade will result in about the same current draw as the 3 bladed 11x6. But with the extra pitch speed you should see much better performance, making it a lot more fun for the instructor! Remember lift goes up by the square function of the speed. So going twice as fast means you can generate 4 times the lift. OK, the counter to this is drag goes up by the cube of the speed. So there is no free lunch!
Its what comes with the plane. Lol. Plus, replacements aren't expensive. Her first plane, and she has to do the assembly, under my watchful eye, so no curveballs outside the book. I'll put a frsky esc in it and the reciever, and set up her X20 for it, then clone it to mine.
FMS has kinda preset the prop and motor, but after a few flights with it, I'll swap the motor out for one Wayne stocks so I KNOW exactly what it has and how good. Be same size, kv, etc. She'll know exactly what she has, vs something fms just tossed in. Same goes for servos. By the time she's soloing it will be a top notch trainer with all reliable gear.
I'll end up doing the same with the mustang. Servo starts making noise, be raiding Wayne's shelves.
Her first non trainer will be all aloft radio and electrics as will my next one...whatever that may be lol. (Hint..its going to have two engines and is also known as the fork tailed devil...)
