Blejzyk FIRST 2-meter Polyhedral Build
There is no structural strength in bonding the foam core. Per the manual you are to under cut the foam adjacent to the veneer skin. This is to allow an adhesive (epoxy) bead to form. This bead is what binds the stress skins of the panels to each other.
Thanks Konrad
[URL unfurl="tr
Thank You
will look in to that
the First 2M building guide says nothing about poly tips
seems to be guide to building the First + two piece wing
mac
The KS HD 47MG is a pretty tiny servo for a plane this size, but if the goal is to keep her light, I suspect you will be fine.
thank you
what size servo should i be using with this plane
is there a chart or guide to figuring out what size servo should be using with what size plane
yours truly
mac
At this size (weight and speed) of aircraft, servo selection is more of an art than a science. The HD-47mg will work and work well at 7.4V. But it really is too light and the gears are a bit delicate for this application. Since you will be needing to add nose weight, saving on servo weight gains you nothing. As this set up uses pushrods (snakes) their weight will place a large stress on the gears when the nose hits anything. The delicate gears even though they are metal might not survive well.
For your glider the ubiquitous 9 gram servo would work. But as you need nose weight I’d look for the added durability that the 17 gram to 24 gram class of servo with its larger gear train.
thanks Konrad
enjoying this bit of learning, was ordering larger servos thought heck while am at it ordered a Blejzyk UMI kit
yours truly
mac
