Binding S8R receivers to ETHOS Radios
lcadavid
I own two FrSky radios operating with ETHOS, HORUS X10S EXPRESS and X20. I also have two FrSky ACCST S8R receivers, among other receivers (ACCST and ARCHER). The problem I am having is that I am not able to properly bind the S8R receivers to the ETHOS radios. I had no issues before when working with OpenTX. The binding process running in the radio never closes to an OK prompt. If I do RTN and recycle the receiver I get a very weak link and RSSI signal. I cannot get the stabilizing functions to work properly either. Radios and receivers have the most up to date firmware.
Have any other fliers reported this kind of issues? Any help or direction on where to find a solution with this will be highly appreciated. Thank you.
Luis Cadavid
lcadavid@earthlink.net
(561)313-2891
Luis Cadavid
(561)313-2891
By clicking return during the Binding process you are not completing the binding process, you need to click the enter button on the right hand side of your radio. Also in ACCESS mode you need to register first then bind.
Thank you for your reply and your suggestions. I do not use the return button because the radio never shows the "Bind Complete" pop up, but I I will give it a try.
Note these are ACCST D16 receivers and there is no registration for these. Registration is for ACCESS receivers.
Thanks again.
