Binding Problem.
I just received 3 receivers from Aloft. G-RX8. I can not get any of the 3 receivers to bind. I am using 3 other receivers in other aircraft and I had not problem binding them. I have even copied another aircraft in the transmitter and changed the receiver number and tried to bind with no success. These receivers were on back order for a while before I got them. Has anything changed. They will not bind into pwm or s-bus. Any Ideas/
Yes, what version of ACCST are you running? Both the RX and TX need to be on the same primary protocol revision number V1.x.xx or V2.1.x.
This video shows how to read the TX to see what version of RF Protocol you have on the TX
Unfortunately you can't read what is on the RX so you just need to download a known firmware and record this for your future records.
I suspect you are still using the dangerous ACCST v1.1.16. Please up date all your ACCST RF products to ACCST v2.1.xx
@David Whitaker - I think I saw your post on RC Groups. Sounds like you may have ACCST V1 on your transmitter and I think the receivers may have ACCST V2 on them. We have asked FrSky to give us a sticker so we know for sure.. Anyhow, if you like, we can change out the firmware on the receivers, no charge. Just confirm what you need and send them in and we can do that for you. Or if you like, it isn't too hard to do yourself.
Let us know if you need any pointers, happy to help.
