Batteries "C" rate
Rcrooman
How do you determine a batteries "C" rate. Example: 7.2 volt {6 dbl A}, NimHi battery with 2,600MAH.
Thanks
Gary
C-rating is a metric of how much power a battery can continuously provide as well as in short time periods. Certain cell types have fairly generalized C-rating limits (ie Li-ions), however finding the C-rating of your battery will be difficult. They are determined by the battery construction, chemistry, and quality. Manufacturers provide this spec, so I would recommend to try and find the battery online. There are far too many variables to accurately determine C-rating on most battery packs. You could get a rough idea after a lot of testing, but not worth your time IMO.
Are you asking for a safe charge or discharge current? It has to do with the internal impedance of the cell. "C" rating is a marketing term. But the OEM should be able to provide the data you seek (safe currents). Absent any real data for equipment grade NiMh I charge at a current of (Capacity/10).
A discharge C rate on an AA NiMH is going to be very low. The charge rate in C for the same battery will be about 1/10th of a C as I recall. AKA, tiny!
