Thanks guys, this is really helpful. Didn't realize the micro ballons were pointless, good to know.
I hadn't thought of the added space to move the CG, glad I asked!
Thanks!
Ralf
THIS IS A STICK-UP!!
Ralf - I give microballoons (MB's) to people that I don't like for Christmas presents.
MB's add nothing to any build except built-in weakness. They don't add lightness, they dilute your epoxy, adding ZERO strength.
They are not thixotropic and they are really difficult to use as they are microscopically round. If applied in a very thick mix ratio, still wont work. MB's can only be built up in thin (time consuming/weak) layers. They simply automatically flatten rather than clinging to the surfaces of the parts to be joined. They are not even easy to sand.
Good for pattern casting applications, probably - but this is not something we normally do..
Cabosil is far lighter than any microballoons and as Konrad says it also deletes strength - but to a far less degree than MB, and Cabosil CAN applied in thick (read: one-shot) layers.
As I have said and Konrad too, most organic fibres can be used as an epoxy filler and other artificial ones too. I like wood dust because I have a lot of it around, but if you want really super good strength, then a mixture of milled glass, or better yet, glass/carbon fibres with a little Cabosil added to keep it together is numero uno.
Good luck, and welcome to the sticky fingers brigade!
