I have been using the internal until today when I used the T type from a RadioMaster module for the second round of radio checks and a short flight.Has there been any mention of which TX antenna Gizmo6 is using. Internal or external, could he be using the external antenna without one being plugged in. ?
I placed the model on a wooden run up stand about 40 inches high and walked out to around 100 feet and armed which is my record trigger. I then made a 360 around the model attempting to maintain the same distance, this was done with internal and external antennas for the 2.4GHz.
Next I took a short flight and kept the distance to 200 yards or less, only had one time where the model didn't seem to respond to stick input but only got a couple of RSSI low call outs.
Switched to 2 different models one with an Archer SR8 Pro the other with a SR10 Pro both of which performed much better at distance than the R4, starting to think the R4 is going to be retired.
The flight was with the external 2.4 GHz antenna.
The reception seems to be problematic when above and left of the Tx which would put it roughly in line with the end of the T antenna.
I have another R4 and a R-XSR that I have ACCESS FW for, I think its time to try another Rx and see if the results change.
I might try replacing the antennas and doing a range check with just the problem R4 and a battery, if that shows an improvement I can reinstall it in the Altus and flight test it.
Yes the back has been off, once to replace a RTC battery and recently to check the antenna cables. Will be going in a 3rd time to replace the power board as the rudder trim right is now inop.I need to ask if you have ever had the Transmitter back off resulting in the possible damage of the short antenna cables.
This mornings testing pretty much points to a bad R4, I swapped in a RX6R and only used the internal antennas as the range check was much better than the R4. the one large dip in signal quality was due to vehicles parked between the Tx and Rx at one point in the 360° arc.
The flight was without any audible warnings and I got much further away both in altitude and distance.
The Tx only shows two active Rx in the RF System page, RX6R and R9MINI-O, RX3 is unassigned. I am even less of an ETHOS expert so I don't know a missing Rx would do more than throw RSSI / VFR warnings.
That is a possibility that I will investigate when the new power board arrives. The logs would seem to indicate good power out when not trying to communicate with a bum Rx but while the Tx is open I will have a close look at all connections.Is that last connector on the right possibly canted a little bit? It's hard to be sure from the photo.
Guess I'm going blind, yes once I looked by row number I see the same thing. I will send this to the guy I know that works at the service center and see if he can make sense of it.Good call on inspecting the raw data.
I looked at InternalAntennaRadioCheck.csv and found RX2 listed as active in row 49. I didn't check the other files. I'd be curious to know if you learn anything more.
Are you sure all the antennae are connected? In the image the white one on the right looks not flat, though it could be an illusion.Yes the back has been off, once to replace a RTC battery and recently to check the antenna cables. Will be going in a 3rd time to replace the power board as the rudder trim right is now inop.
