@Jarron Should be able to run some options for you tomorrow.
I suspect the answer is going to be no. The spar is rather small as this is a smallish 2 meter ship with a smaller cross section. I'd think 1000 watts would be just as fast as 3000 in this airframe and wing. She is a slippery model. A local ran a shortened Tracer wing (down to 1.5m) in an F3F race and beat several 3 meter ships, that is normally not even possible.
The spar on this model is sized fine for the intended use, but pushing high G loads with a heavy model over 150mph I think would be a risky move IMHO. The Magnus has the same sized joiner and I have seen that model take insane abuse without issue, but it also has a shorter span.
If you must go huge power, I think the Aeroic models would be the better option, they have massive joiners for their size.
