Antenna Question.
iflylilplanes
Strong User
I have a X4R that has lost both it's antennas, cut off by the prop in a hard landing, the receiver itself is untouched. I wish to replace the antennas but, which type?
My question is, will going to the Dipole antennas be better for reception/range or, should I carry on with the standard whisker antennas?
Or should I run one of each?.
In my early 2.4gig days I used the Turnigy 9X (Flysky) gear, all the receivers had the Dipole antennas, I never had range issues, I do get the odd low RSSI warning with my Taranis. I don't fly FPV, 90 percent of my flying is within 250 metres but for glider comp days. My gliders use RX4R and RX6R receivers and have never had any issues.
You can use either style. FrSky claimed a little better range with the dipole, but then they did away with them, so not so sure it amounted to much.
Pretty sure you have the Ipex 4 connector.
