Other than having to make a 3mm high jelly bean flap servo cover I think I'm done with the build of this Great Wall (Alpha 2.8).
The last thing to do was install the wing servos. Now as counter intuitive as it seems I don't try to place the control surface in profile with the wing when the servo is centered. Instead I calculate the total amount of throw a surface needs divide by 2 and use this value to set the control surface when the servo is centered. In the case of this Alpha 2.8 my flaps could move 22° up. Total flap movement was 112° (AKA 90+22=112). So divide by 2 means that I want the surface at 56° with the servo centered. This means that at servo center the flaps should be down 34° using the in profile as zero for the 34° measurement.
For the ailerons I want a 2:1 differntial. Total aileron up was 40° so I would want 20° down aileron. Center would be 10° up aileron.
I took the easy way out and just used what the control wipers would allow. I could have fitted the wipers to get more throw but The numbers as is looked ok to me.
What I like about using the throw center to set the servo center is that if I have to change servo arms the effect will be close to the same at each end of the servo throw.
Now the sharp eyed amongst you will have noticed that my flap servo is not centered well in the flap servo opening. This is a habit I seem to have in that I I almost always choose too short a push rod for my flaps. I do this as I don't want to crash into the wing spar. With the Alpha 2.8 and the Servorahmen IDS the next longer pushrod at 66mm would have been a better fit.
Now I need to give a shout out to OpenTX and Mike Shelium's F3F templet. With Mike's templet it is real easy to adjust for any mechanical offset errors in the placement of the control surface spoons and servo arms. This addresses any unwanted servo throw differential or cosine errors. It also allows one to custom match the surface throws on each side. That is the left and right flaps move the same and the same amount. Same goes for the ailerons. This goes along way towards making a well behaved aircraft!
So with the build done all I have to do is balance the model repair the cosmetic damage (paint the black on the fuselage and wing bottom) and set up Mike's templet. Still not sure what I'm going to do with the white wing panel.
