This will be a discussion of the TJIRC Alpha 2.8 as sold by Aloft Hobbies.
What drove me to look at the TJIRC Alpha 2.8 was that I damaged my two RCRCM Stregas' in the first race of the NCSS F3F season. I hate to say it but it looks like I'll be behind the power curve trying to keep some kind of F3F ship ready for racing.
I went into Aloft Hobbies to get a next level up F3F ship. As is typical with Wayne at Aloft Hobbies I came out with a different ship than I was planing to buy. This is a good thing as I went in wanting to get an $1500 Rotmilan. This is a nice older well proven F3F ship. After my talk with Wayne it was decided that I really shouldn't destroy such a nice classic ship as the Rotmilan (Ok, he was out of stock). Wayne actually down sold me a TJIRC Great Wall 2.8m carbon lay up glider. While a bit smaller than the RCRCM Stregas' I'm flying, the TJIRC Great Wall will actually be a huge step up. At $850 dollars it is one of the best valued gliders out there in the 2.7 to 3 meter F3F class of carbon ship!
Add to the great NIB value I got an even larger price break as the TJIRC Great wall 2.8 I got had some shipping damage to the wing tip. To be honest my ships all look this beat up after the first test flight!
I'm of the opinion that TJIRC is a huge step up from what we get with RCRCM products. Basically they are what an RCRCM product might look like if manufactured properly (for the price point). That is to say TJIRC planes are a great value!
Wayne tells me that the TJIRC Great Wall is the exact same model as the one he is marketing as the TJIRC Alpha 2.8. So from here on out I'll be calling this a TJIRC Alpha 2.8.
Wow, this is a Strega killer! While being a bit smaller at 2.8m it's design and construction are much better than the RCRCM Strega.
The first thing I noticed is that the cloth lay ups in the wing are biased at 45°. This costs a bit more as there is more waste at the end of the cloth bolts. But this makes for a wing that is much better at resisting torsional loads.
The second thing I saw was that the shear webs are place in what looks like a carbon sock. This will help with the bonding between the two heavy carbon caps and stabilize the shear web's grain. This is a nod to a real spar! I also notice that there are oversized and properly placed carbon stiffeners to spread the wing servo loads.
While Wayne did say the Great Wall and the Alpha 2.8 are the same I did noticed that this Great Wall has a set of 11.9mm round ballast tubes in the wings. Most Alpha 2.8s that I've seen have a rectangular ballast tube. I like the round tube as I think it might be easier to find tungsten ballast rod. But I think most folks are actually using rectangular brass as ballast. The only downside I see is the 11.9 is too small for a 12mm rod!
The wings of the TJIRC Alpha 2.8 are a bit thinner at 19mm, than those on the RCRCM Strega which are 19.5mm thick. The only odd thing I notice is the convex wing TE and the wider tips than those of the Strega. I don't know what these style features will do to the roll rate and stall of the wing.
Now what caught my attention was the fuselage. It is so much better than the RCRCM Strega's. First it has a longer tail boom (I love long boom gliders)! The servo tray is a bottom feeder with slip on nose cone. This adds a lot of crash resistance as there are now a lot more fibers on the top of the nose holding the nose in place on most landing (read my hard landings). I also like that the slip on nose cone part line is slated forward a bit. This again was done to align the structure with the landing loads. It looks like the fuse has a full carbon layup aft of the wing leading edge!
This brings me to one of the few concerns I have. The nose appears to have a lot of carbon strips as nose stiffeners. I fear these may block most 2.4 gHz signals. I'd have liked to see some heavy kevlar rather that carbon in the nose.
Now what baffles me Is how am I to actuate the V-tail flippers? I see that TJIRC has supplied me with 1.7mm wire control horns and two full length 5 mm carbon push rods. But I fail to see how I'm going to get these control horns past the fuselage sides into the fuselage center bulb. Right now I'm thinking I'll have to cut the fuselage side from the control horn axis all the way to the fuse top opening. while that would work I don't like the idea. (I guess it really is no worse than the aft tail cone we got with the Strega). If anybody knows how this was to be done please let me know. I'm thinking that the V-tails are thick enough that I might place a set of KST X0-8 in the stabs and set up the V-Tail as a fly by wire and do away with the 5mm carbon push rods.
