Alpha 2.0 Antenna Placement
austin
So I finally get to finish up my Alpha 2.0 kit! Using a FrSky receiver with two antenna where would you mount them? It seems right behind the canopy is all carbon with the area under the canopy is mostly fiberglass with carbon strips. If I'm not mistaken the wings have a bunch of carbon fiber. While trying to keep the antenna at 90 degrees from each other where would you mount them? Thanks!
I like them behind wing exit hole for wires and it keeps receiver away from the ESC. I tried them in the front, but they were blocked by the wing when they blew back during flying.
Upvote 0
I have always kept them up in the nose. Nothing hanging out. I try to be careful with where the antennas end up. FrSky manages to tolerate less than ideal setups pretty well. But always make sure the volume on the radio is turned up so you can hear any warnings.
Upvote 0
