Alpenbrise electric power
Raymond Gaskins
Reaching out to Doc Hammond and others for recommendations for an electric power system for my new Alpenbrise (recently received from Aloft).
Have flown two and three meter sailplanes with electric systems installed, but no experience in setting up such a system on my own. No slopes within easy driving range for me and want a reliable motor, prop, esc and battery combo optimal for this gorgeous work of art! Additionally, want equipment that is currently available as I am anxious to fly this one.
Thanks in advance,
Raymond
Hi Raymond,
go to Composite RC Gliders and tap Alpenbrise. At the bottom of the page, the complete power train set up is listed inc prop. This is for the model seen in the videos seen on this forum.
Thanks in advance,
Raymond
Raymond,
I have asked the Guys at CRG for thier latest setup as I think they have changed it. I have also asked one of the European fliers - a certified nutcase with an Alpenbrise - what he and the others are favouring.
As soon as I have news you'll be the first to know.
Raymond,
As soon as I have new you'll be the first to know.
Doc,
Thank you for your help!
Raymond
Hi Raymond - here is what Humbricht Bliebler (Switzerland) uses: Note: he highly recommends a direct drive motor:
From Humbricht: "Hallo James Thank you very much for your message! I have installed in my Alpenbrise a direct drive system less noise than a gear system and much cheaper. Also I use a separate Liio Akku for the receiver whenever I have space I don’t trust the BEC or I install a backup system. I include the parts installed in pictures so you can see the details."
Hope it helps.
There’s a bit of right thrust evident in Humbricht’s photo. Wonder if that was built in, or added after flight testing?
I think it may have been added Jonty - if it was built in you probably wouldn't be able to see it from that angle.
So far, if it is right thrust its the only one I have seen. All the rest are straight as far as I know.
Hope it helps.
Doc.View attachment 14010View attachment 14011View attachment 14012View attachment 14013View attachment 14014View attachment 14015
Doc,
Thank you for the assistance.
Hope to get started on the build soon.
Raymond
Doc,
Raymond
Great, please let me know if you have any other questions, Raymond.
Doc,
Raymond
One more bit of info from Sebastian Franken - CRG test pilot and partner:
Our recommended setup works fine. Easy hand launch a good climb rate of 12m/s and a motor runtime of around 2,5 mins.
I think a direct drive variant is also possible. Maybe an A40 with 17x10 on 4S (ASW28) or a A40 with 13x8 on 6S (new AS33). Both Models have similar weight and wingspan like the Alpenbrise but lower basic speed. I would try one of these configs.
Th
Thanks again Doc,
Do you know if CRG can be accessed on the web in English? My Deutch is a bit rusty and I definitely want to get the prop and spinner from them as I cannot find either of them at another site. I have ordered the Hacker motor and ESC first recommended and it appeared they also sold a motor mount as well.
Raymond
Raymond your messages are disappearing - please reply to the message I sent you here if you get it.
Hello Doc,
Don’t know how my messages disappeared.
I was enquiring if an on line assembly manual existed for the Alpenbrise. I can figure things out I am sure but have delayed unpacking the Alpenbrise until I have all the parts I ordered together. I am using the parts recommended on the German website with direct drive geared inrunner motor and the IDS linkages (I have never installed these before and understand some videos that illustrate their installation).
Thanks
Raymond
Hello Doc,
Thanks
Raymond
Raymond - can you see my message to you in the Conversations section top right?
Otherwise can you message me at aeroicplanes@gmail.com
There is a blow-by-blow picture and setup manual.
Doc
Looks like Iain Rose is managing to brave the fierce British spring weather with his orange Alpenbrise. This one is the third one out of the mould and has been flown very hard by Iain ever since he got it, depite it being an "S" version. Iain is well known for his 'stressful' flying style.
Man that is pretty!! Hope I get to see one at Sunset.
Red
