Alpenbrise design notes.
Doc J
Hi Guys - probably time to explain how I came up with the Alpenbrise - actually a detailed design pholophy can be found here:
Essentially; and I make no bones about this - the Alpenbrise was designed to be a real "next generation" Alpina. Anyone who has seen an orginal Alpina will love its lines, and if you have flown one then...OK I'll leave that one blank - but I dare venture to say that anyone who has seen its 2000, 3000, 4000 etc derivatives will be disappointed at how much those same lines deteriorated. Not sure about the flying qualities.
So I set out to change all that.
The idea was simply to design a good looking, fast, aerobatic and efficient 4M (157") Alpine/Slope glider as what I (and possibly I alone) conceived to be where the original Alpina SHOULD have gone. As a design aside, if it could be easily electrified then that would be a bonus. So with those short requirements in mind I set pen to paper.
Please note carefully here and now that the Alpenbrise was NOT designed to compete in any FAI racing or other class, athough it does conform - with an electric set up - to the GPS lght class. Therefore I did not design the nose to the F3f nose radius, and as to the safety aspects required on FAI models, well thats pretty funny as you'll see below.
The FAI F3f nose radius is a dubious safety feature as all of the FAI electric classes use really sharp, pointy, highly dangerous, lethal, mortally threatening, razor honed spinners - so I guess we can dispense with the hypocritical safety aspects - or is it just that the FAI electric competitiors fly more safely than the F3f bunch? No bloody idea.
The aerodynamics of the model follow the line of developments I have been making for a number of years where the high aspect ratio wing planform follows a reversed ellipse format. The wings are simply clipped at the ends, as until now I can find no lower drag or more slippery exit shape. I even tried the upright winglets so popular these days, but my conclusion was that on a slope glider they save very little fuel. And thats a comment about how useful those winglets are on anything under 6M.
The basic reversed Ellipse wing design is to try to take advantage of an elliptical lift pattern which is practical and puts the lift where its needed and nowhere else; but in doing that I also had to try to deal with the inherent problems of a truly elliptical wing - lovely though they do look. On a truly elliptical wing there is a really nasty problem - especially if its a high aspect ratio ellipse, and that is that the MAC (Mean aerodynamic chord) and the CG (Centre of gravity) ARE TOO CLOSE TOGETHER. This makes the wing far too prone to stalling as the two salient forces involved are interacting, sometimes unpedictably due to close proximity.
SEPARATING those forces helps with this problem, and you can continue with this philosphy by lowering the aspect ratio until the MAC and the CG separate really far, which can eliminate the conventional stall altogether. This is what you sometimes see on a low aspect ratio delta - there is no actual stall - just a mushy descent.
So Alpenbrise is not an FAI model and was never designed to be one, so if it doesn't conform to FAI regulations in any way - other than weight of course - then thats not unduly surprising. It does have curvy lines so was never suitable for (Heaven forbid) a slip on nosecone, its a high end sport model that can be used for light class GPS with the addition of an electric motor setup - and a sharp spinner🤣 - and a whole bunch of associated electornics.
I hope the build quality is improving because I'm sure as hell trying to get it better, and have been for many years.
Alpenbrise is what it is: A high end 4M Slope or Alpine sport model - that can be electrified (if you want to risk those razor-sharp spinners:poop:) and used for FAI GPS Light cass. Period.
The model has been reviewed in the European mags very favourably by some very picky pilots, with the testers commenting esecially on the model's durability, lack of wing flexing, speed and aerobatics capabiity - plus the lack of any kind of bad behaviour even when induced. There are now over 40 flying in Europe and 28 more on order which must say something for the design as its only been out for a year or so.
I'm happy to answer any sensible questions by the way.
Alpenbrise 157 models in their coats of many colours...
These on the QC tables here are 12 that are headed to Europe along with with some smaller models, while 2 more special A157 planes from this production batch are coming to USA.
The great Banos bash is coming, and Banos is a killer place for a four meter model.
I see Wayne has some A157 planes on offer - I might think about that if I was mulling a larger high performance model, as the prices are likely to go up with the next shipment. In europe these models sell for almost twice Aloft's prices, and they cant keep them on the shelves.
Same situation with the smaller planes and the Aeroic/CRG specials.
Hello Doc, New Alpenbrise owner here with a couple questions about servo linkages. Is there an offset clevis to horn connection (flaps and Ailerons) that fits better than what was included? or do I cut the notch out another 1/4 inch or so and tape on a cover??
I really like the design of the plane and the builder did a great job ! I can't wait to fly it..
Thanks for your help..
Rob
Rob
Hi Rob,
I'm sorry I cant quite understand what you mean - can you make a simple sketch?
Cheeers,
So if I clip on the clevis to the flap or aileron horn It won't move much as it's bound up...I've seen in the past some clevises have a small step right after the connection that would help a little..
Or, do I cut more of the slot and add a cover? I'm stuck as to how this gets connected...
Any photos or build threads?
Thanks again, Rob
Thanks again, Rob
Rob do you have the instructions?
If not, please give me your email on PM above and I'll send them to you. Too big to post here.
In some cases you may need to trim a bit of material to get your clevis to properly clear. This depends on the clevis used. It can be a bit of a pain. Just make sure everything is smooth running.
Aeroic test pilot Red Jensen finally got his hands on the A157 Alpenbrise test model and needless to say, its very RED. In fact its the only red one made so far. Red will do the installation and hopefully testing in the next few weeks.
Quotes Red on opening the box:
"Let the build begin! Overall impressions are this is a very nice bird. Pre-wired harness, wing and fuse ballast options, nice G-10 radio tray and hardware kit. Gonna be awesome!"
Watch this space.
BTW that's Red's assistant Test Pilot, son Ryan holding the red bird. More on that in another thread later.
I got a little bit of a start tonight. I am using GDW servos and my favorite Tomas Liu LDS hardware. The install seems pretty straight forward. Plenty of room in the wings, so this should be a fairly easy assembly.
thank you Red.
  • Love
