Yes, we like the look!
I know nothing about boats, but is the term you are looking for sheer web? Something to keep the load bearing members apart. I’ve been known to fill tail booms with 30x expanding polyurethane for this very purpose, as a fix. This is done to keep the boom from kinking.
But from a design perspective I’d like to see a larger diameter tube. As I recall the stiffness of a tube goes up by the square of the diameter. So a boom that has twice the diameter will be 4 time as stiff assuming the cross section of the material is kept the same.
Please again - do remember
this is a big plane, guys - much larger than most of you fly right now.
Having foam sheer webs in the fuse is actually a really good idea though, in the same way as the sine wave spar AND wing sheer ribs do such great things for high A/R wings.
The way I do it is the same that I have used all along:
1. Decided the envelope or the work of the model.
2. Do the sums an select the sections that will be best for the work.
3. Try to make it look sweet but without sacrificing the original design parameters and the things needed to meet them.
I have now been doing this for a fair while, and I think that especially with the new factory in the picture, it can be made very light and strong with really good induced and sympathetic vibration damping.
Remember too that once the moulds are made we can then mess about with the internal construction to our hearts content - and as you know, or I hope you know, I DO LISTEN to people.
More comments please, lads! I need all the help I can get.
