jvaliensi
Active User
I bought the kit about 15 years ago. I never built a model with foam core, wood covered wings with servos in the wings. This method appears to be out dated.
What is the best way to hold the servos on the foam? I'm thinking a plywood backer plate glued on the foam.
This sailplane has four servos. The KST 8 V5 fits the best in the aileron spot. It has 2.2kg-cm of torque. I wonder if this enough? I'll use more powerful flap servos and mix them together in flight.
The fuselage is so huge that two full sized servos are lost in it. Instead of adding lead to balance it, I'll use a 5000mah 2s battery from a RC car!
