Air Speed Sensor
  • Thread starter Thread starter SidGates
  • Start date Start date
S
SidGates
Guest
i have tried the FrSky airspeed sensor in two different models and in both I get inaccurate speed reports several times during each flight. Has anyone else had this problem?
I have 2 N2 airspeed sensors that work perfectly.
I'm not aware of any issues. You do need to make sure that pitot is getting clean air and is direct into the wind. Other than that the only thing I can think of is to make sure the tubes are not pinched or bouncing in the air.
I had the pitot mounted in clean air but the lines may have been flapping. It is now installed with very short lines and no flapping possible so will see if then works OK.
